주요 콘텐츠로 건너뛰기
Alienware M11xR2 Display Assembly Replacement
필요한 것
  1. Alienware M11xR2 Display Assembly Replacement, Disconnecting Antenna Cable: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the antenna cables from the Mini-Card(s).
  2. Alienware M11xR2 Display Assembly Replacement, Removing Mimi Card: 2 단계, 이미지 1개 중 1개
    • The routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
  3. Alienware M11xR2 Display Assembly Replacement, Turning Over The Computer: 3 단계, 이미지 1개 중 1개
    • Turn the computer over and open the display as far as possible.
  4. Alienware M11xR2 Display Assembly Replacement, Pulling The Pull-Tab: 4 단계, 이미지 1개 중 1개
    • Pull the pull-tab to disconnect the display cable from the connector on the system board.
  5. Alienware M11xR2 Display Assembly Replacement, Removing Screws: 5 단계, 이미지 1개 중 1개
    • Remove the four screws that secure the display assembly to the computer base.
  6. Alienware M11xR2 Display Assembly Replacement, Removing Mini-Card cable: 6 단계, 이미지 1개 중 1개
    • Gently slide the Mini-Card antenna cables out through the slot on the computer base.
  7. Alienware M11xR2 Display Assembly Replacement, Lifting Display Assembly: 7 단계, 이미지 1개 중 1개
    • Lift the display assembly off the computer.
  8. Alienware M11xR2 Display Assembly Replacement, Sliding New Cables: 8 단계, 이미지 1개 중 1개
    • Slide the antenna cables in through the slot on the computer base.
  9. Alienware M11xR2 Display Assembly Replacement, Securing Screws: 9 단계, 이미지 1개 중 1개
    • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
  10. Alienware M11xR2 Display Assembly Replacement, Connecting New Display Cable: 10 단계, 이미지 1개 중 1개
    • Connect the display cable to the connector on the system board.
  11. Alienware M11xR2 Display Assembly Replacement, Rerouting  The Mini-Card Cable: 11 단계, 이미지 1개 중 1개
    • Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
  12. Alienware M11xR2 Display Assembly Replacement, Connecting Mini-Card Cables: 12 단계, 이미지 1개 중 1개
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
darrius
회원 가입일: 03/26/18
5,213 평판
안내서 30개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,996개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 18
전체 시간: 662
