이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
The routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
Pull the pull-tab to disconnect the display cable from the connector on the system board.
Remove the four screws that secure the display assembly to the computer base.
Gently slide the Mini-Card antenna cables out through the slot on the computer base.
Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
다른 2명이 해당 안내서를 완성하였습니다.
