주요 콘텐츠로 건너뛰기
Alienware M14xR2 Optical Drive Replacement
필요한 것
  1. Alienware M14xR2 Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Optical Drive Replacement: 2 단계, 이미지 1/3 Alienware M14xR2 Optical Drive Replacement: 2 단계, 이미지 2/3 Alienware M14xR2 Optical Drive Replacement: 2 단계, 이미지 3/3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Optical Drive Replacement: 4 단계, 이미지 1/3 Alienware M14xR2 Optical Drive Replacement: 4 단계, 이미지 2/3 Alienware M14xR2 Optical Drive Replacement: 4 단계, 이미지 3/3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Optical Drive Replacement, Optical Drive: 5 단계, 이미지 1/3 Alienware M14xR2 Optical Drive Replacement, Optical Drive: 5 단계, 이미지 2/3 Alienware M14xR2 Optical Drive Replacement, Optical Drive: 5 단계, 이미지 3/3
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordan Ramsey
회원 가입일: 09/30/13
402 평판
안내서 1개 작성함
Cal Poly, Team 13-4, Forte Fall 2013 Cal Poly, Team 13-4, Forte Fall 2013 회원
CPSU-FORTE-F13S13G4
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 2,719
