이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the computer off.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
Slide the back cover towards you and then lift upwards to remove.
Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
Pull up on the white connector to disconnect it from the laptop.
The battery is now free to remove from the laptop and can be set aside.
Unscrew the four 6.35 mm size 1 screws.
Pull up on the end of the orange tab to detach it from the white connector.
Lift the optical drive up and out of the laptop and set it aside.
다른 한 분이 해당 안내서를 완성하였습니다.
