소개
This guide will show you how to safely access and replace the RAM sticks for the Alienware M14xR2 laptop. In order to remove the RAM you need to first remove the battery and the CD drive.
도구
부품
지정된 부품이 없습니다.
Turn the computer off.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Unscrew the four 6.35 mm size 1 screws.
Pull up on the end of the orange tab to detach it from the white connector.
Lift the optical drive up and out of the laptop and set it aside.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 3개
How max is the ram upgrade compatible with the m14x ifixit?!
doantuan85 - 답글
I meaned r1 model
doantuan85 - 답글
