주요 콘텐츠로 건너뛰기
Alienware M14xR2 Status-Light Board Replacement
필요한 것
  1. Alienware M14xR2 Status-Light Board Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Status-Light Board Replacement: 2 단계, 이미지 1/3 Alienware M14xR2 Status-Light Board Replacement: 2 단계, 이미지 2/3 Alienware M14xR2 Status-Light Board Replacement: 2 단계, 이미지 3/3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Status-Light Board Replacement: 3 단계, 이미지 1/1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Status-Light Board Replacement: 4 단계, 이미지 1/3 Alienware M14xR2 Status-Light Board Replacement: 4 단계, 이미지 2/3 Alienware M14xR2 Status-Light Board Replacement: 4 단계, 이미지 3/3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: 5 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Turn the palm-rest assembly over.
  6. Alienware M14xR2 Status-Light Board Replacement, Remove the Cable: 6 단계, 이미지 1/1
    • Note the routing of status-light board cable and remove the cable from the routing guides.
    • NOTE: If the status-light board cable is under the speakers cable, remove the speakers cable first and then remove the status-light board cable.
  7. Alienware M14xR2 Status-Light Board Replacement, Turn the Palm-Rest Assembly Over: 7 단계, 이미지 1/1
  8. Alienware M14xR2 Status-Light Board Replacement, Remove the Screw: 8 단계, 이미지 1/1
    • Remove the screw that secures the status-light board to the palm-rest assembly.
  9. Alienware M14xR2 Status-Light Board Replacement, Lifting the Status-Light Board: 9 단계, 이미지 1/1
    • Carefully lift the status-light board and release its cable from the slot on the palm-rest assembly.
  10. Alienware M14xR2 Status-Light Board Replacement, Slide the Status-Light Board Cable: 10 단계, 이미지 1/1
    • Slide the NEW status-light board cable through the slot in the palm-rest assembly.
  11. Alienware M14xR2 Status-Light Board Replacement, Align the Slot: 11 단계, 이미지 1/1
    • Align the slot on the status-light board with the alignment post on the palm-rest assembly.
  12. Alienware M14xR2 Status-Light Board Replacement, Replace the Screw: 12 단계, 이미지 1/1
    • Replace the screw that secures the status-light board to the palm-rest assembly.
  13. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: 13 단계, 이미지 1/1
  14. Alienware M14xR2 Status-Light Board Replacement, Routing the Status-Light Board Cable: 14 단계, 이미지 1/1
    • Route the status-light board cable through the routing guides on the palm-rest assembly.
결론
Terrence15
회원 가입일: 12/18/17
79,091 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 한 개
Völliges Durcheinander und unvollständig
Robert Fleischhauer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 660
