주요 콘텐츠로 건너뛰기
Alienware M15x Compartment Door Replacement
필요한 것
  1. Alienware M15x Compartment Door Replacement, Battery: 1 단계, 이미지 1/3 Alienware M15x Compartment Door Replacement, Battery: 1 단계, 이미지 2/3 Alienware M15x Compartment Door Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Alienware M15x Compartment Door Replacement, Compartment Door: 2 단계, 이미지 1/2 Alienware M15x Compartment Door Replacement, Compartment Door: 2 단계, 이미지 2/2
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Alienware M15x Compartment Door Replacement: 3 단계, 이미지 1/3 Alienware M15x Compartment Door Replacement: 3 단계, 이미지 2/3 Alienware M15x Compartment Door Replacement: 3 단계, 이미지 3/3
    • Slide the compartment door towards the front of the computer and lift.
결론
Jake Alexander
회원 가입일: 01/22/18
85 평판
안내서 1개 작성함
Cal Poly, Team S11-G3, Banghart Winter 2018 Cal Poly, Team S11-G3, Banghart Winter 2018 회원
CPSU-BANGHART-W18S11G3
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 347
