주요 콘텐츠로 건너뛰기
Alienware M15x Hard Drive Replacement
필요한 것
  1. Alienware M15x Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 Alienware M15x Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 Alienware M15x Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Alienware M15x Hard Drive Replacement, Compartment Door: 2 단계, 이미지 1/2 Alienware M15x Hard Drive Replacement, Compartment Door: 2 단계, 이미지 2/2
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Alienware M15x Hard Drive Replacement: 3 단계, 이미지 1/3 Alienware M15x Hard Drive Replacement: 3 단계, 이미지 2/3 Alienware M15x Hard Drive Replacement: 3 단계, 이미지 3/3
    • Slide the compartment door towards the front of the computer and lift.
  4. Alienware M15x Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Use Phillips #1 screwdriver to loosen the four screws on the hard drive enclosure.
  5. Alienware M15x Hard Drive Replacement: 5 단계, 이미지 1/2 Alienware M15x Hard Drive Replacement: 5 단계, 이미지 2/2
    • Once the screws are loosened use the "PULL" tab to remove the current hard drive from the computer.
  6. Alienware M15x Hard Drive Replacement: 6 단계, 이미지 1/2 Alienware M15x Hard Drive Replacement: 6 단계, 이미지 2/2
    • Remove the four small screws indicated to remove the casing to the hard drive.
  7. Alienware M15x Hard Drive Replacement: 7 단계, 이미지 1/1
    • Now take off the SATA converter and then connect it to the drive you would like to replace it with.
결론
David Sann
회원 가입일: 01/22/18
111 평판
안내서 1개 작성함
Cal Poly, Team S11-G3, Banghart Winter 2018 Cal Poly, Team S11-G3, Banghart Winter 2018 회원
CPSU-BANGHART-W18S11G3
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 850
