주요 콘텐츠로 건너뛰기
Alienware M15x Hard Drive Replacement
필요한 것
  1. Alienware M15x Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Alienware M15x Hard Drive Replacement: 2 단계, 이미지 1/3 Alienware M15x Hard Drive Replacement: 2 단계, 이미지 2/3 Alienware M15x Hard Drive Replacement: 2 단계, 이미지 3/3
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Alienware M15x Hard Drive Replacement: 3 단계, 이미지 1/2 Alienware M15x Hard Drive Replacement: 3 단계, 이미지 2/2
    • Unscrew the four screws indicated
    • Pull on the tab that says "Pull" and remove the Hard Drive
  4. Alienware M15x Hard Drive Replacement: 4 단계, 이미지 1/2 Alienware M15x Hard Drive Replacement: 4 단계, 이미지 2/2
    • With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Gabe
회원 가입일: 04/09/10
8,013 평판
안내서 3개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,529개 작성하였습니다
댓글 한 개
Thanks, great guide. Was a bit confused between steps three and four but I simply had to remove the metal casing around the hard drive.
Hasan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 33,041
