소개
Upgrade your RAM for an instant increase in speed.
The M15x uses DDR3 1333MHz memory.
  1. First, take off the battery by moving the latch to the left and pulling it up.
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Then unscrew the two Phillips screws. Pull the cover down, then up, revealing the internals Pull the cover down, then up, revealing the internals
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Unscrew the two screws indicated
    • Unscrew the two screws indicated
  5. Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Gabe
회원 가입일: 2010년 04월 09일
8,074 평판
안내서 3개 작성하였습니다
Master Techs Master Techs 회원
Community
286 회원들
안내서 808개 작성하였습니다
I saw somewhere that it actually takes DDR2 ram not DDR3....
John Moreau - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 23,967
