주요 콘텐츠로 건너뛰기
Alienware M17-R1 Hard Drive Replacement
필요한 것
  1. Alienware M17-R1 Hard Drive  Replacement, Battery: 1 단계, 이미지 1/1
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 Hard Drive  Replacement: 2 단계, 이미지 1/1
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 Hard Drive  Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Place the laptop face down on a hard, flat surface to have a clear view of the bottom of the computer.
  4. Alienware M17-R1 Hard Drive  Replacement: 4 단계, 이미지 1/1
    • Once you have located the hard drive, you will then need to remove the 3 mm screw using the Phillips #1 screwdriver.
  5. Alienware M17-R1 Hard Drive  Replacement: 5 단계, 이미지 1/1
    • Gently slide the hard drive away from the computer using the built in ridges.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
LXA054
회원 가입일: 10/09/18
337 평판
안내서 3개 작성하였습니다
Sam Houston State, Team S15-G2, Blackburne Fall 2018 Sam Houston State, Team S15-G2, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G2
4 회원들
안내서 5개 작성하였습니다
댓글 2개
where can I get the two hdd doors
Rebecca Anne Guidroz - 답글
Hello I guess I got lucky running across this site my 2200 dollar laptop has been a brick paper weight since Mr Gates dropped support of Vista leaving a lot of non savvy pc techs hanging no where to turn prayfully this fix it site can breath new life into my Alienwares gaming mr17 r1 hard drive once more blowing dust off ("cough") as I write this help me please .
Mike Hogan Sr - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 19
전체 시간: 707
