주요 콘텐츠로 건너뛰기
Alienware M17-R1 RAM Replacement
필요한 것
  1. Alienware M17-R1 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 RAM Replacement: 2 단계, 이미지 1/1
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Place laptop down on a hard flat surface to begin the disassembly.
  4. Alienware M17-R1 RAM Replacement: 4 단계, 이미지 1/2 Alienware M17-R1 RAM Replacement: 4 단계, 이미지 2/2
    • Remove the nine 3 mm screws that secure the cover using a Phillips #1 screwdriver.
  5. Alienware M17-R1 RAM Replacement: 5 단계, 이미지 1/1
    • Once the cover is removed, locate the RAM compartment to begin the replacement.
  6. Alienware M17-R1 RAM Replacement: 6 단계, 이미지 1/2 Alienware M17-R1 RAM Replacement: 6 단계, 이미지 2/2
    • After locating the RAM, gently pull the two metal clips outward and lift the RAM card out of its socket.
    • The card will pop up once it has been released and can be removed.
  7. Alienware M17-R1 RAM Replacement: 7 단계, 이미지 1/1
    • To insert the new RAM, place it on top of the socket and carefully apply downward pressure until it snaps into place.
결론
LXA054
회원 가입일: 10/09/18
337 평판
안내서 3개 작성하였습니다
Sam Houston State, Team S15-G2, Blackburne Fall 2018 Sam Houston State, Team S15-G2, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 644
