주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware M17-R1 Screen Lock Assembly Replacement
필요한 것
  1. Alienware M17-R1 Screen Lock Assembly Replacement, Screen Lock Assembly: 1 단계, 이미지 1개 중 1개
    • Open the screen until it is flat.
    • Ensure that the surface you are working on can support both the screen and the base of the laptop.
  2. Alienware M17-R1 Screen Lock Assembly Replacement: 2 단계, 이미지 2개 중 1개 Alienware M17-R1 Screen Lock Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the eight 7 mm screws around the edge of the screen using a Phillips #1 screwdriver.
    • Support the screen from the bottom to make it easier to remove the screws.
  3. Alienware M17-R1 Screen Lock Assembly Replacement: 3 단계, 이미지 2개 중 1개 Alienware M17-R1 Screen Lock Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool and gently slide it around the edge of the screen to lift the face of the screen away from its base.
    • Be careful not to break the face of the screen when lifting it.
  4. Alienware M17-R1 Screen Lock Assembly Replacement: 4 단계, 이미지 3개 중 1개 Alienware M17-R1 Screen Lock Assembly Replacement: 4 단계, 이미지 3개 중 2개 Alienware M17-R1 Screen Lock Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
    • Pull the assembly grip away to remove it.
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  5. Alienware M17-R1 Screen Lock Assembly Replacement: 5 단계, 이미지 2개 중 1개 Alienware M17-R1 Screen Lock Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Push in the assembly towards the spring.
    • Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
    • The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
  6. Alienware M17-R1 Screen Lock Assembly Replacement: 6 단계, 이미지 2개 중 1개 Alienware M17-R1 Screen Lock Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • If the spring is defective, slide it off the end of the assembly and replace it.
결론
작성자
2다른 기여자 명과 함께
William Davis
회원 가입일: 10/09/18
323 평판
안내서 2개를 작성함
Sam Houston State, Team S15-G2, Blackburne Fall 2018 Sam Houston State, Team S15-G2, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G2
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 48
전체 시간: 673
