주요 콘텐츠로 건너뛰기
Alienware M17x Hard Drive Replacement
필요한 것
  1. Alienware M17x Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Alienware M17x Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x Hard Drive Replacement: 4 단계, 이미지 1/2 Alienware M17x Hard Drive Replacement: 4 단계, 이미지 2/2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/1
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your hard drive(s).
  6. Alienware M17x Hard Drive Replacement: 6 단계, 이미지 1/3 Alienware M17x Hard Drive Replacement: 6 단계, 이미지 2/3 Alienware M17x Hard Drive Replacement: 6 단계, 이미지 3/3
    • Remove the eight 3.5 mm Phillips #0 screws.
    • Remove the hard drive(s), using the Plastic Opening Tool by lifting on the edges and pulling the hard drive up and out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mosier Locke
회원 가입일: 09/27/18
729 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 13
전체 시간: 2,352
