소개
If your laptop is incapable of performing routine tasks or recognizing when USB devices are plugged in, use this guide to remove and replace your motherboard.
필요한 것
Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
Twelve 5.5 mm Phillips #0 main frame screws.
Six 3.5 mm Phillips #0 fan screws.
Four 3.5 mm Phillips #0 internal compartment screws.
Eight 3.5 mm Phillips #0 Hard Drive screws.
Four 3.5 mm Phillips #0 CD Drive screws.
거의 끝나갑니다!
결론
