주요 콘텐츠로 건너뛰기
Alienware M17x P01E Center Control Cover Replacement
필요한 것
  1. Alienware M17x P01E Center Control Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E Center Control Cover Replacement: 2 단계, 이미지 1/2 Alienware M17x P01E Center Control Cover Replacement: 2 단계, 이미지 2/2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E Center Control Cover Replacement, Compartment Door: 3 단계, 이미지 1/1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E Center Control Cover Replacement: 4 단계, 이미지 1/2 Alienware M17x P01E Center Control Cover Replacement: 4 단계, 이미지 2/2
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: 5 단계, 이미지 1/3 Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: 5 단계, 이미지 2/3 Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: 5 단계, 이미지 3/3
    • Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan.
  6. Alienware M17x P01E Center Control Cover Replacement: 6 단계, 이미지 1/2 Alienware M17x P01E Center Control Cover Replacement: 6 단계, 이미지 2/2
    • Turn the laptop top side up and fully open the display.
    • The center control panel is between the display and the keyboard. Fully opening the display ensures that there is enough room to pry and lift the center control panel.
    • Pry the center control panel up from its left and right edges with the Spudger.
    • The center control panel may require a decent amount of force to pry free. Do not immediately lift the panel from the laptop once it has been pried free. A cable is connected from the laptop to the center control panel.
  7. Alienware M17x P01E Center Control Cover Replacement: 7 단계, 이미지 1/2 Alienware M17x P01E Center Control Cover Replacement: 7 단계, 이미지 2/2
    • Lift the center control panel from the laptop.
    • Tilt the center control panel away from the display carefully.
    • Lift the latch open to remove the cable connecting from the laptop to the center control panel.
결론
Grant Dolmat
회원 가입일: 09/17/18
328 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team S2-G2, Bruce Fall 2018 CSU Fullerton, Team S2-G2, Bruce Fall 2018 회원
CSUF-BRUCE-F18S2G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 419
