주요 콘텐츠로 건너뛰기
Alienware P18G M14X R1 Hard Drive Replacement
필요한 것
  1. Alienware P18G M14X R1 Hard Drive Replacement, Back Cover: 1 단계, 이미지 1/1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Hard Drive Replacement, Battery: 4 단계, 이미지 1/1
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Hard Drive Replacement: 5 단계, 이미지 1/2 Alienware P18G M14X R1 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
  7. Alienware P18G M14X R1 Hard Drive Replacement, Optical Drive: 7 단계, 이미지 1/1
    • Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
  8. Alienware P18G M14X R1 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Using the plastic opening tool unclip the white connector holding down the orange cable.
  9. Alienware P18G M14X R1 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
  10. Alienware P18G M14X R1 Hard Drive Replacement, Hard Drive: 10 단계, 이미지 1/1
    • Loosen the three 6.35 mm screws using the PH1 screw driver, to release the hard drive.
    • The screws will not be able to be removed from the hard drive. They can only be loosened or tightened.
  11. Alienware P18G M14X R1 Hard Drive Replacement: 11 단계, 이미지 1/1
    • Pull the tab on the hard drive slowly and carefuly because there will be a cable attached to it.
  12. Alienware P18G M14X R1 Hard Drive Replacement: 12 단계, 이미지 1/1
    • Pull the clip away from the hard drive to remove it.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Andonaq Grozdani
회원 가입일: 03/01/18
892 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 UMass Dartmouth, Team S2-G2, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S2G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 25
전체 시간: 2,869
