주요 콘텐츠로 건너뛰기
Alienware X51 Heatsink Replacement
필요한 것
  1. Alienware X51 Heatsink Replacement, Front Panel: 1 단계, 이미지 1/1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Heatsink Replacement: 2 단계, 이미지 1/1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Heatsink Replacement, Fan: 3 단계, 이미지 1/2 Alienware X51 Heatsink Replacement, Fan: 3 단계, 이미지 2/2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Heatsink Replacement: 4 단계, 이미지 1/1
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Heatsink Replacement: 5 단계, 이미지 1/3 Alienware X51 Heatsink Replacement: 5 단계, 이미지 2/3 Alienware X51 Heatsink Replacement: 5 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
  6. Alienware X51 Heatsink Replacement, Heatsink: 6 단계, 이미지 1/3 Alienware X51 Heatsink Replacement, Heatsink: 6 단계, 이미지 2/3 Alienware X51 Heatsink Replacement, Heatsink: 6 단계, 이미지 3/3
    • Loosen the four 10.0 mm screws around the heatsink with a Phillips #1 screwdriver until you hear a click.
    • These are captive screws and cannot be fully removed.
    • Remove the heatsink by gently prying and lifting it up.
결론
alondra
회원 가입일: 10/02/23
123 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 76
