주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware X51 R1/R2/R3 RAM Replacement
필요한 것
  1. Alienware X51 R1/R2/R3 RAM Replacement, Remove Panel Screw: 1 단계, 이미지 1개 중 1개
    • First, turn the computer so you can see the rear panel. Remove the small screw to the right (or above, if the system is on its side) of the audio jacks.
    • Once the screw is removed, use both hands to push the side panel down and towards the front of the case.
  2. Alienware X51 R1/R2/R3 RAM Replacement, Disconnect LED Control Cable: 2 단계, 이미지 1개 중 1개
    • Lift the side panel off, and gently flip it over the top of the system, being careful not to break the LED control cable. Unplug its connector and set the case panel to the side.
  3. Alienware X51 R1/R2/R3 RAM Replacement, Remove Fan Screws: 3 단계, 이미지 1개 중 1개
    • Next, remove the screws securing the plastic air re-director (not shown in picture) to the fan, and gently lift it out of the case. Set aside and move to the next step.
  4. Alienware X51 R1/R2/R3 RAM Replacement, Disconnect/Remove the DVD Drive: 4 단계, 이미지 1개 중 1개
    • Unplug the SATA cable at the base of the DVD drive circled in blue. This cable will have a lot of tension on it, but do not worry. Just be careful not to yank on it too much.
    • You will then unscrew the screw securing the DVD drive to the case (circled in red). Once the screw is removed, remove the DVD drive and set to the side.
  5. Alienware X51 R1/R2/R3 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Now, push the white latch (circled in red) DOWN and pull the ram card straight up to a ~45 degree angle. Pull up and out, towards the latch side, and set aside.
  6. Alienware X51 R1/R2/R3 RAM Replacement, Insert New Ram Card: 6 단계, 이미지 1개 중 1개
    • You will insert the new DIMM. Push the side opposite to the latch in first, being sure that the notch in the connector matches the location on the ram DIMM.
    • Insert at a ~45 degree angle and push straight down into the socket, being sure that the latch clicks.
    • DO NOT FORCE THE DIMM IN. Rotate the card and try again if the card will not go into the port.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Daniel Niles
회원 가입일: 02/12/16
163 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 56
전체 시간: 6,652
