주요 콘텐츠로 건너뛰기
Alienware m15 R6 SSD slot one Replacement
필요한 것
  1. Alienware m15 R6 SSD slot one Replacement, Base Cover: 1 단계, 이미지 1개 중 1개
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 SSD slot one Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 SSD slot one Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 SSD slot one Replacement, Removing the solid-state drive in SSD slot one: 4 단계, 이미지 2개 중 1개 Alienware m15 R6 SSD slot one Replacement, Removing the solid-state drive in SSD slot one: 4 단계, 이미지 2개 중 2개
    • Remove the two screws (M2x4) that secure the thermal shield to the solid-state drive and the system board.
    • Lift the thermal shield off the solid-state drive.
    • Slide and lift the solid-state drive off the solid-state drive slot on the system board.
  5. Alienware m15 R6 SSD slot one Replacement, Procedure to move the screw mount in SSD slot one: 5 단계, 이미지 1개 중 1개
    • Slide to remove the screw mount from the palm-rest and keyboard assembly.
    • Slide the screw mount into the other screw mount slot on the palm-rest and keyboard assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Andrzej
회원 가입일: 02/17/23
1,702 평판
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 326
