주요 콘텐츠로 건너뛰기
소개
PREREQUISITE
부품
지정된 부품이 없습니다.
  1. Alldaymall A88X Back Cover, Alldaymall A88X Back Cover: 1 단계, 이미지 1/3 Alldaymall A88X Back Cover, Alldaymall A88X Back Cover: 1 단계, 이미지 2/3 Alldaymall A88X Back Cover, Alldaymall A88X Back Cover: 1 단계, 이미지 3/3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Back Cover: 2 단계, 이미지 1/1
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
결론
Drhaber
회원 가입일: 2016년 02월 10일
985 평판
안내서 7개 작성하였습니다
USF Tampa, Team 4-1, Lacy Spring 2016 USF Tampa, Team 4-1, Lacy Spring 2016 회원
USFT-LACY-S16S4G1
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 33
