주요 콘텐츠로 건너뛰기
Alldaymall A88X Battery Replacement
필요한 것
  1. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: 1 단계, 이미지 1/3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: 1 단계, 이미지 2/3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: 1 단계, 이미지 3/3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Battery Replacement: 2 단계, 이미지 1/1
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Battery Replacement, Battery: 3 단계, 이미지 1/3 Alldaymall A88X Battery Replacement, Battery: 3 단계, 이미지 2/3 Alldaymall A88X Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to server any of these.
  4. Alldaymall A88X Battery Replacement: 4 단계, 이미지 1/3 Alldaymall A88X Battery Replacement: 4 단계, 이미지 2/3 Alldaymall A88X Battery Replacement: 4 단계, 이미지 3/3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  5. Alldaymall A88X Battery Replacement: 5 단계, 이미지 1/2 Alldaymall A88X Battery Replacement: 5 단계, 이미지 2/2
    • Desolder the wires that connect the battery to the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Alex
회원 가입일: 02/10/16
101 평판
안내서 1개 작성함
USF Tampa, Team 4-1, Lacy Spring 2016 USF Tampa, Team 4-1, Lacy Spring 2016 회원
USFT-LACY-S16S4G1
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 1,105
