주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AlphaSmart Pro Lithium Coin Battery Replacement
필요한 것
  1. AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: 1 단계, 이미지 3개 중 1개 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: 1 단계, 이미지 3개 중 2개 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: 1 단계, 이미지 3개 중 3개
    • Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery.
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: 2 단계, 이미지 2개 중 1개 AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: 2 단계, 이미지 2개 중 2개
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
  3. AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: 3 단계, 이미지 2개 중 1개 AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: 3 단계, 이미지 2개 중 2개
    • With the front panel removed, locate the lithium coin battery at the top left corner of the motherboard.
  4. AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: 4 단계, 이미지 2개 중 1개 AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: 4 단계, 이미지 2개 중 2개
    • Use the spudger, plastic opening tool, or your finger/fingernail to lift up the lithium coin battery.
    • Slide the battery out from underneath the clip that holds it in place.
    • The positive side of the battery is facing up.
결론
작성자
3다른 기여자 명과 함께
Katy Beth Culp
회원 가입일: 10/13/14
1 평판
안내서 2개를 작성함
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 회원
CLEM-BENSON-F14S1G1
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 81
전체 시간: 1,343
