주요 콘텐츠로 건너뛰기
AlphaSmart Pro Motherboard Replacement
필요한 것
  1. AlphaSmart Pro Motherboard Replacement, Separating Panels: 1 단계, 이미지 1/3 AlphaSmart Pro Motherboard Replacement, Separating Panels: 1 단계, 이미지 2/3 AlphaSmart Pro Motherboard Replacement, Separating Panels: 1 단계, 이미지 3/3
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: 2 단계, 이미지 1/3 AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: 2 단계, 이미지 2/3 AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: 2 단계, 이미지 3/3
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • Remove front panel from the motherboard.
  3. AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: 3 단계, 이미지 1/3 AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: 3 단계, 이미지 2/3 AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: 3 단계, 이미지 3/3
    • Use the Phillips #00 Screwdriver to remove the four 1 cm screws from each corner of the keyboard.
    • Gently lift the keyboard from the rear panel.
    • Notice that the keyboard is still connected to the motherboard by two ribbon cables.
  4. AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: 4 단계, 이미지 1/3 AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: 4 단계, 이미지 2/3 AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: 4 단계, 이미지 3/3
    • To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable.
    • Pull the ribbon cable to remove it from the connector.
    • Repeat the exact steps above for the other ribbon cable.
    • While the large connector on the left must be pulled toward you in order to remove the ribbon cable, the smaller connector on the right must be pushed away from you.
  5. AlphaSmart Pro Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove keyboard from motherboard.
  6. AlphaSmart Pro Motherboard Replacement, Disconnecting Battery Prongs From Battery Compartment: 6 단계, 이미지 1/2 AlphaSmart Pro Motherboard Replacement, Disconnecting Battery Prongs From Battery Compartment: 6 단계, 이미지 2/2
    • Flip the AlphaSmart Pro over so that the rear panel is facing upward.
    • Using a spludger, carefully disconnect the battery prongs, located in the battery compartment.
  7. AlphaSmart Pro Motherboard Replacement, Separating Motherboard From Rear Panel.: 7 단계, 이미지 1/2 AlphaSmart Pro Motherboard Replacement, Separating Motherboard From Rear Panel.: 7 단계, 이미지 2/2
    • Using a Phillips #00 Screwdriver, remove the four 0.8 cm screws from the motherboard.
    • Carefully lift the motherboard away from the rear panel.
결론
Ashley Orr
회원 가입일: 10/13/14
130 평판
안내서 2개 작성하였습니다
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 회원
CLEM-BENSON-F14S1G1
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 481
