주요 콘텐츠로 건너뛰기
Alpine MRV-M500 Circuit Board Replacement
필요한 것
  1. Alpine MRV-M500 Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1/3 Alpine MRV-M500 Circuit Board Replacement, Circuit Board: 1 단계, 이미지 2/3 Alpine MRV-M500 Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3/3
    • Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
  2. Alpine MRV-M500 Circuit Board Replacement: 2 단계, 이미지 1/2 Alpine MRV-M500 Circuit Board Replacement: 2 단계, 이미지 2/2
    • Remove all Phillips 7.5mm, 12.5mm, and 10.5mm screws holding the circuit board to the case.
    • Make sure the device has been powered off and disconnected from the power source for at least a day before touching the electronic components.
  3. Alpine MRV-M500 Circuit Board Replacement: 3 단계, 이미지 1/1
    • Remove the circuit board from the case.
결론
To reassemble your device, follow these instructions in reverse order using the replacement circuit board.
다른 4명이 해당 안내서를 완성하였습니다.
Eric Gaulke
회원 가입일: 09/17/18
623 평판
안내서 3개 작성하였습니다
Washington State, Team S2-G6, Hope Fall 2018 Washington State, Team S2-G6, Hope Fall 2018 회원
WSU-HOPE-F18S2G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 35
전체 시간: 2,123
