주요 콘텐츠로 건너뛰기
Alpine Ski Wax Application
필요한 것
  1. Alpine Ski Wax Application, Alpine Ski Wax Application: 1 단계, 이미지 1/1
    • Attach heavy rubber bands around the brakes.
  2. Alpine Ski Wax Application: 2 단계, 이미지 1/1
    • Spray base cleaner along the bottom of the ski.
  3. Alpine Ski Wax Application: 3 단계, 이미지 1/1
    • Wipe the skis with a towel, removing dirt, excess wax, the base cleaner, and dust.
  4. Alpine Ski Wax Application: 4 단계, 이미지 1/1
    • Spread wax across the base of the ski with an edge to edge motion. While doing this hold the iron perpendicular to the base and press the wax into the iron.
    • Be careful when handling the hot iron and the hot wax.
  5. Alpine Ski Wax Application: 5 단계, 이미지 1/1
    • Melt the wax into the base using a tip to tail stroke with the iron.
    • Let the skis dry for at least 30 minutes once all the wax is melted.
  6. Alpine Ski Wax Application: 6 단계, 이미지 1/1
    • Scrape the excess wax off with the plastic scraper. Continue this process until there is no visible wax on the ski base.
  7. Alpine Ski Wax Application: 7 단계, 이미지 1/1
    • Scrape the excess wax off of the side of the ski.
  8. Alpine Ski Wax Application: 8 단계, 이미지 1/1
    • Wipe the fine wax dust from the ski base.
결승점
Evan Gornick
회원 가입일: 09/26/17
101 평판
안내서 1개 작성함
Michigan Tech, Team S5-G4, Galliah Fall 2017 Michigan Tech, Team S5-G4, Galliah Fall 2017 회원
MTU-GALLIAH-F17S5G4
2 회원들
안내서 2개 작성하였습니다
댓글 8개
Very nice post! That's a great website I have visited, thank you for your essentials words run 3
Martin Tolley - 답글
I read your article very detailed and easy to understand, I hope next time you will have more wonderful articles to share with the reader.
run 3
switch color - 답글
thansks for the post
Arun nagar - 답글
'''WYSIWYG Web Builder Crack''' has a unique and easy to use tools for both beginners and professional developers. Hence it is straightforward to use application.
Harry Oscar - 답글
I really enjoy the blog article. Much thanks again. Want more.
Wondershare Filmora Scrn Crack
DxO PhotoLab Crack
Harry Oscar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 14
전체 시간: 406
