주요 콘텐츠로 건너뛰기
Altec Lansing BoomJacket 2 Battery Replacement
필요한 것
  1. Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: 1 단계, 이미지 2개 중 1개 Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: 1 단계, 이미지 2개 중 2개
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Battery Replacement: 2 단계, 이미지 2개 중 1개 Altec Lansing BoomJacket 2 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Battery Replacement: 4 단계, 이미지 2개 중 1개 Altec Lansing BoomJacket 2 Battery Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Battery Replacement, Battery: 7 단계, 이미지 1개 중 1개
    • The battery will be in the middle of the speaker when the case is open.
  8. Altec Lansing BoomJacket 2 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
    • Pull battery up and away from speaker without catching any other components.
    • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zach Braaten
회원 가입일: 07/12/18
537 평판
안내서 4개를 작성함
UW Tacoma, Team S1-G4, Cardinal Summer 2018 UW Tacoma, Team S1-G4, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G4
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 1,841
