주요 콘텐츠로 건너뛰기
Altec Lansing BoomJacket 2 Disassembly
필요한 것
  1. Altec Lansing BoomJacket 2 Disassembly, Altec Lansing BoomJacket 2 Disassembly: 1 단계, 이미지 1/2 Altec Lansing BoomJacket 2 Disassembly, Altec Lansing BoomJacket 2 Disassembly: 1 단계, 이미지 2/2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Disassembly: 2 단계, 이미지 1/2 Altec Lansing BoomJacket 2 Disassembly: 2 단계, 이미지 2/2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Disassembly: 3 단계, 이미지 1/1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Disassembly: 4 단계, 이미지 1/2 Altec Lansing BoomJacket 2 Disassembly: 4 단계, 이미지 2/2
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Disassembly: 5 단계, 이미지 1/1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Disassembly: 6 단계, 이미지 1/1
    • Gently pull apart the front panel from the base of the speaker.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Zach Braaten
회원 가입일: 07/12/18
516 평판
안내서 4개 작성하였습니다
UW Tacoma, Team S1-G4, Cardinal Summer 2018 UW Tacoma, Team S1-G4, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 17
전체 시간: 1,506
