주요 콘텐츠로 건너뛰기
Altec Lansing BoomJacket 2 Motherboard Replacement
필요한 것
  1. Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: 1 단계, 이미지 1/2 Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: 1 단계, 이미지 2/2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Motherboard Replacement: 2 단계, 이미지 1/2 Altec Lansing BoomJacket 2 Motherboard Replacement: 2 단계, 이미지 2/2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Motherboard Replacement: 3 단계, 이미지 1/1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Motherboard Replacement: 4 단계, 이미지 1/2 Altec Lansing BoomJacket 2 Motherboard Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Motherboard Replacement: 6 단계, 이미지 1/1
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Motherboard Replacement, Battery: 7 단계, 이미지 1/1
    • The battery will be in the middle of the speaker when the case is open.
  8. Altec Lansing BoomJacket 2 Motherboard Replacement: 8 단계, 이미지 1/1
    • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
    • Pull battery up and away from speaker without catching any other components.
    • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
  9. Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Disconnect the furthest right hand plug first.
    • Do not pull from the wires. Pull from the white connector.
  10. Altec Lansing BoomJacket 2 Motherboard Replacement: 10 단계, 이미지 1/1
    • Gently pull the motherboard directly upwards to avoid damage.
    • Be sure to lift slowly.
  11. Altec Lansing BoomJacket 2 Motherboard Replacement: 11 단계, 이미지 1/1
    • Disconnect the remaining connectors from the motherboard.
    • Do not forcefully pull connectors. Pull from the connectors, not from the wires.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zach Braaten
회원 가입일: 07/12/18
516 평판
안내서 4개 작성하였습니다
UW Tacoma, Team S1-G4, Cardinal Summer 2018 UW Tacoma, Team S1-G4, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G4
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
Where is the best place to purchase a motherboard for the Altec Lansing Jacket H20 4?
Kelvin Jasper - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 13
전체 시간: 850
