주요 콘텐츠로 건너뛰기
소개
Are you trying to repair a part inside your speaker but need to first remove the case that surrounds the speakers? This guide will help you do just that!
  1. Using your hands, remove the pegs (4+4) from the front and back of the speaker.
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Remove the outer black rubber housing of the speaker.
    • Remove the outer black rubber housing of the speaker.
  3. Remove the inner blue rubber housing from the speaker.
    • Remove the inner blue rubber housing from the speaker.
  4. Pull out the two black wire meshes using a metal spudger.
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Using tweezers remove the rubber stoppers (4 at the back + 2 at the front). Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
    • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
  7. Pull the case apart and you will be able to see all the components inside the speaker.
    • Pull the case apart and you will be able to see all the components inside the speaker.
결론
Ryan Byrnes
회원 가입일: 2017년 04월 12일
803 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 644
