주요 콘텐츠로 건너뛰기
소개
Are your speakers not producing the same amount of BOOM that they used to? Perhaps repairing your speakers is the way to go.
  1. Using your hands, remove the pegs (4+4) from the front and back of the speaker.
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Remove the outer black rubber housing of the speaker.
    • Remove the outer black rubber housing of the speaker.
  3. Remove the inner blue rubber housing from the speaker.
    • Remove the inner blue rubber housing from the speaker.
  4. Pull out the two black wire meshes using a metal spudger.
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Using tweezers remove the rubber stoppers (4 at the back + 2 at the front). Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Using the size PH1 screwdriver remove the screws (4 around each speaker).
    • Using the size PH1 screwdriver remove the screws (4 around each speaker).
  7. Pull the case apart and you will be able to see all the components inside the speaker.
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Remove the speakers (not entirely because of the wiring) by gently pulling each speaker up.
    • Remove the speakers (not entirely because of the wiring) by gently pulling each speaker up.
결론
Ryan Byrnes
회원 가입일: 2017년 04월 12일
803 평판
안내서 5개 작성하였습니다
Where do I find the correct part to replace the charging port on my boom jacket?
Rockstar - 답글
1.1" External Magnetic Type Round Slim Plastic Shell Speaker 8 Ohm 0.25W 2 Pcs
Eeshton -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 581
