소개
If the battery in your Altec Lansing Mini Lifejacket 2 isn't holding a charge or is showing signs of failure, use this guide to replace it.
필요한 것
Use the spudger to remove the eight black pins from the front and back of the wire screens.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 10개
Search for MCR18650 battery. They are available.
F Hickisch - 답글
Hickisch, I appreciate your guide on replacing this battery, but I beg to differ that replacement batteries are “available.” I keep getting sent batteries with 3-wire connectors instead of 2-wire. Plz send me a link, plz. Gracias.
for the mini life jacket 3, the motherboard is upside down so you need to remove it to unplug the battery.
For the mini life jacket 3 can you send what link you had for the battery?
