주요 콘텐츠로 건너뛰기
Altec Lansing VersA Smart Bluebooth Board Replacement
필요한 것
  1. Altec Lansing VersA Smart Bluebooth Board Replacement, External Panels: 1 단계, 이미지 1/1
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Bluebooth Board Replacement: 2 단계, 이미지 1/2 Altec Lansing VersA Smart Bluebooth Board Replacement: 2 단계, 이미지 2/2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Bluebooth Board Replacement: 3 단계, 이미지 1/2 Altec Lansing VersA Smart Bluebooth Board Replacement: 3 단계, 이미지 2/2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Bluebooth Board Replacement: 4 단계, 이미지 1/1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Bluebooth Board Replacement, Bluebooth Board: 5 단계, 이미지 1/1
    • Detach the wiring piece, located in the upper right corner of the motherboard.
  6. Altec Lansing VersA Smart Bluebooth Board Replacement: 6 단계, 이미지 1/2 Altec Lansing VersA Smart Bluebooth Board Replacement: 6 단계, 이미지 2/2
    • Remove the daughterboard piece from its designated slot, located to the right of the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rachael Hopp
회원 가입일: 09/10/18
550 평판
안내서 5개 작성하였습니다
University of Alabama, Team S1-G3, Bedsole Fall 2018 University of Alabama, Team S1-G3, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S1G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 705
