주요 콘텐츠로 건너뛰기
Altec Lansing VersA Smart Micro USB Port Replacement
필요한 것
  1. Altec Lansing VersA Smart Micro USB Port Replacement, External Panels: 1 단계, 이미지 1/1
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Micro USB Port Replacement: 2 단계, 이미지 1/2 Altec Lansing VersA Smart Micro USB Port Replacement: 2 단계, 이미지 2/2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Micro USB Port Replacement: 3 단계, 이미지 1/2 Altec Lansing VersA Smart Micro USB Port Replacement: 3 단계, 이미지 2/2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Micro USB Port Replacement: 4 단계, 이미지 1/1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Micro USB Port Replacement, Micro USB Port: 5 단계, 이미지 1/1
    • Remove the plactic piece containing the Micro USB port from its designated slot, found below the speakers.
  6. Altec Lansing VersA Smart Micro USB Port Replacement: 6 단계, 이미지 1/1
    • Detach both the wires connecting the Micro USB piece to the motherboard.
  7. Altec Lansing VersA Smart Micro USB Port Replacement: 7 단계, 이미지 1/1
    • Remove the two 10mm screws using the Phillips #0 screwdriver.
  8. Altec Lansing VersA Smart Micro USB Port Replacement: 8 단계, 이미지 1/1
    • Remove the small black plastic piece that was held in place by the two 10 mm screws and covers the Micro USB port.
  9. Altec Lansing VersA Smart Micro USB Port Replacement: 9 단계, 이미지 1/1
    • Use the black plastic spudger to lightly push the Micro USB piece out of the external plastic piece.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rachael Hopp
회원 가입일: 09/10/18
550 평판
안내서 5개 작성하였습니다
University of Alabama, Team S1-G3, Bedsole Fall 2018 University of Alabama, Team S1-G3, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S1G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 939
