소개
If you are having various issues with your device, this guide will show you how to remove and replace the motherboard.
  1. Remove external rubber cover.
    • Remove external rubber cover.
  2. Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
      • Use a lever motion, push the tool down, lifting the speaker face.
      • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
      • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
    • Remove the five wiring attachments (for the volume board, bluetooth board, speakers, and microUSB) from their connection to the motherboard by pulling slightly.
    • Remove the two 9mm screws holding the motherboard in place using the Torx T5 screwdriver.
    • Remove the motherboard.
결론
Kendra Pennington
회원 가입일: 2018년 09월 10일
97 평판
안내서 1개 작성함
University of Alabama, Team S1-G3, Bedsole Fall 2018 University of Alabama, Team S1-G3, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S1G3
3 회원들
안내서 6개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 29
전체 시간: 48
