메인 콘텐츠로 스킵하기
소개
If you are having issues with sound quality, this guide will show you how to remove the two speakers found within your device.
  1. Remove external rubber cover.
    • Remove external rubber cover.
  2. Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom. Use a lever motion, push the tool down, lifting the speaker face.
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side. Remove the seven 14mm screws using the Phillips #1 screwdriver.
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Detach the two wire connections from the motherboard. Remove the speaker bed from the internal cavity of the device. Remove the speaker bed from the internal cavity of the device.
    • Detach the two wire connections from the motherboard.
    • Remove the speaker bed from the internal cavity of the device.
  6. Orient speaker bed so the speaker heads are facing up. Remove the two 14mm screws using the Phillips #1 screwdriver.
    • Orient speaker bed so the speaker heads are facing up.
    • Remove the two 14mm screws using the Phillips #1 screwdriver.
  7. Separate the two plastic pieces of the speaker bed. Flip the top plastic piece so the speaker heads are face down.
    • Separate the two plastic pieces of the speaker bed.
    • Flip the top plastic piece so the speaker heads are face down.
    • Speaker heads may fall out on their own.
    • Remove the two speaker heads.
결론
Rachael Hopp
회원 가입일: 2018년 09월 10일
517 평판
안내서 5개 작성하였습니다
University of Alabama, Team S1-G3, Bedsole Fall 2018 University of Alabama, Team S1-G3, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S1G3
3 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 53
