주요 콘텐츠로 건너뛰기
Altec Lansing VersA Smart Speaker Head Replacement
필요한 것
  1. Altec Lansing VersA Smart Speaker Head Replacement, External Panels: 1 단계, 이미지 1개 중 1개
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Speaker Head Replacement: 2 단계, 이미지 2개 중 1개 Altec Lansing VersA Smart Speaker Head Replacement: 2 단계, 이미지 2개 중 2개
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Speaker Head Replacement: 3 단계, 이미지 2개 중 1개 Altec Lansing VersA Smart Speaker Head Replacement: 3 단계, 이미지 2개 중 2개
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Speaker Head Replacement: 4 단계, 이미지 1개 중 1개
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: 5 단계, 이미지 3개 중 1개 Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: 5 단계, 이미지 3개 중 2개 Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: 5 단계, 이미지 3개 중 3개
    • Detach the two wire connections from the motherboard.
    • Remove the speaker bed from the internal cavity of the device.
  6. Altec Lansing VersA Smart Speaker Head Replacement: 6 단계, 이미지 2개 중 1개 Altec Lansing VersA Smart Speaker Head Replacement: 6 단계, 이미지 2개 중 2개
    • Orient speaker bed so the speaker heads are facing up.
    • Remove the two 14mm screws using the Phillips #1 screwdriver.
  7. Altec Lansing VersA Smart Speaker Head Replacement: 7 단계, 이미지 2개 중 1개 Altec Lansing VersA Smart Speaker Head Replacement: 7 단계, 이미지 2개 중 2개
    • Separate the two plastic pieces of the speaker bed.
    • Flip the top plastic piece so the speaker heads are face down.
    • Speaker heads may fall out on their own.
    • Remove the two speaker heads.
결론
작성자
2다른 기여자 명과 함께
Rachael Hopp
회원 가입일: 09/10/18
550 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 607
