메인 콘텐츠로 스킵하기
소개
Prying the case open will inevitably cause damage. This method disengages the catches to allow the case to be easily opened by hand.
The technique is probably applicable to the Intel Mini which has similar catches, but has not been tried.
부품
지정된 부품이 없습니다.
  1. Instead of a putty knife a dozen or more 1-1/2" pins are required.
    • Instead of a putty knife a dozen or more 1-1/2" pins are required.
  2. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  3. With the computer upside down identify the apertures where the catches are located along either side and also at the front. Insert the pins from the adjacent apertures between the wall and each catch. Be very careful to keep the pins against the case wall.  This is more obvious from the second photo with the case removed.
    • With the computer upside down identify the apertures where the catches are located along either side and also at the front.
    • Insert the pins from the adjacent apertures between the wall and each catch. Be very careful to keep the pins against the case wall. This is more obvious from the second photo with the case removed.
  4. Lift the case off from the back first.
    • Lift the case off from the back first.
    • Remove the pins from the main assembly.
결론
Re-assembly does not require the pins. Place the case over the computer and press down evenly on the sides, not the middle. Ensure the back panel is correctly aligned before finally pushing home the catches.
다른 14명이 해당 안내서를 완성하였습니다.
Donald Todd
회원 가입일: 2010년 09월 22일
472 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 22
전체 시간: 13,686
