주요 콘텐츠로 건너뛰기
Aluratek ADMPF310F Motherboard Replacement
필요한 것
  1. Aluratek ADMPF310F Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Aluratek ADMPF310F Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Aluratek ADMPF310F Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Motherboard Replacement: 2 단계, 이미지 1/1
    • Lift screen out of place so you can access the plugs that connect it.
  3. Aluratek ADMPF310F Motherboard Replacement: 3 단계, 이미지 1/2 Aluratek ADMPF310F Motherboard Replacement: 3 단계, 이미지 2/2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the mother board.
    • Be careful as this zif connector is very frail plastic.
  4. Aluratek ADMPF310F Motherboard Replacement: 4 단계, 이미지 1/1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Motherboard Replacement: 5 단계, 이미지 1/1
    • Pull out remote receiver out of its clip.
    • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
  6. Aluratek ADMPF310F Motherboard Replacement: 6 단계, 이미지 1/2 Aluratek ADMPF310F Motherboard Replacement: 6 단계, 이미지 2/2
    • Using fingers pull the first speaker wire that is located closest to the speakers
    • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
  7. Aluratek ADMPF310F Motherboard Replacement: 7 단계, 이미지 1/3 Aluratek ADMPF310F Motherboard Replacement: 7 단계, 이미지 2/3 Aluratek ADMPF310F Motherboard Replacement: 7 단계, 이미지 3/3
    • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
  8. Aluratek ADMPF310F Motherboard Replacement: 8 단계, 이미지 1/1
    • Pull up the smaller end of the motherboard.
    • Apply force pulling away from the USB ports to get the mother board out of place.
결론
Pascal Alexis
회원 가입일: 11/05/15
427 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 5-1, Martin Fall 2016 UMass Dartmouth, Team 5-1, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 19
전체 시간: 568
