주요 콘텐츠로 건너뛰기
Aluratek ADMPF310F Screen Replacement
필요한 것
  1. Aluratek ADMPF310F Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 Aluratek ADMPF310F Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 Aluratek ADMPF310F Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Screen Replacement: 3 단계, 이미지 2개 중 1개 Aluratek ADMPF310F Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the motherboard.
    • Be careful as this clip is very frail.
  4. Aluratek ADMPF310F Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
결론
작성자
3다른 기여자 명과 함께
Chris Belair
회원 가입일: 10/20/16
333 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-1, Martin Fall 2016 UMass Dartmouth, Team 5-1, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G1
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 8
전체 시간: 582
