주요 콘텐츠로 건너뛰기
Amana Freestanding Electric Range Burners and Rims Replacement
필요한 것
  1. Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: 1 단계, 이미지 1/3 Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: 1 단계, 이미지 2/3 Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: 1 단계, 이미지 3/3
    • Turn the knob for the desired burner to full heat.
    • If there is an unusual amount of heat or no heat, continue.
  2. Amana Freestanding Electric Range Burners and Rims Replacement: 2 단계, 이미지 1/3 Amana Freestanding Electric Range Burners and Rims Replacement: 2 단계, 이미지 2/3 Amana Freestanding Electric Range Burners and Rims Replacement: 2 단계, 이미지 3/3
    • Turn off the burner and let it cool.
    • Remove the burner after it has cooled by grabbing the edge and carefully pulling the element at a slight upward angle.
  3. Amana Freestanding Electric Range Burners and Rims Replacement: 3 단계, 이미지 1/1
    • Clean the burner element end with a wire brush or a metal sponge.
  4. Amana Freestanding Electric Range Burners and Rims Replacement: 4 단계, 이미지 1/2 Amana Freestanding Electric Range Burners and Rims Replacement: 4 단계, 이미지 2/2
    • Take one end of the element and bend it by 3.2 mm to make better contact with the socket inside.
  5. Amana Freestanding Electric Range Burners and Rims Replacement: 5 단계, 이미지 1/2 Amana Freestanding Electric Range Burners and Rims Replacement: 5 단계, 이미지 2/2
    • Place the new burner rim in the space with the hole for the element.
    • Make sure it is aligned with the socket.
  6. Amana Freestanding Electric Range Burners and Rims Replacement: 6 단계, 이미지 1/2 Amana Freestanding Electric Range Burners and Rims Replacement: 6 단계, 이미지 2/2
    • Gently push the restored element through the hole into the socket.
  7. Amana Freestanding Electric Range Burners and Rims Replacement: 7 단계, 이미지 1/1
    • Turn the knob to full heat after all steps are completed to test that it is working.
결론
Refer to guides on repairing electrical components of electric stove burners or seek professional help if the guide does not help solve the problem.
다른 2명이 해당 안내서를 완성하였습니다.
Boluwatife Daniel Madandola
회원 가입일: 05/25/23
169 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 44
전체 시간: 364
