주요 콘텐츠로 건너뛰기
Amazon Echo 2nd Generation Front Cover Panel Replacement
필요한 것
  1. Amazon Echo 2nd Generation Front Cover Panel Replacement, AMP Board: 1 단계, 이미지 1/3 Amazon Echo 2nd Generation Front Cover Panel Replacement, AMP Board: 1 단계, 이미지 2/3 Amazon Echo 2nd Generation Front Cover Panel Replacement, AMP Board: 1 단계, 이미지 3/3
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
  2. Amazon Echo 2nd Generation Front Cover Panel Replacement: 2 단계, 이미지 1/3 Amazon Echo 2nd Generation Front Cover Panel Replacement: 2 단계, 이미지 2/3 Amazon Echo 2nd Generation Front Cover Panel Replacement: 2 단계, 이미지 3/3
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
  3. Amazon Echo 2nd Generation Front Cover Panel Replacement: 3 단계, 이미지 1/2 Amazon Echo 2nd Generation Front Cover Panel Replacement: 3 단계, 이미지 2/2
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
  4. Amazon Echo 2nd Generation Front Cover Panel Replacement, Subwoofer (speaker): 4 단계, 이미지 1/2 Amazon Echo 2nd Generation Front Cover Panel Replacement, Subwoofer (speaker): 4 단계, 이미지 2/2
    • Remove the four 30.0 mm T8 Torx screws in the corners.
    • Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
  5. Amazon Echo 2nd Generation Front Cover Panel Replacement: 5 단계, 이미지 1/2 Amazon Echo 2nd Generation Front Cover Panel Replacement: 5 단계, 이미지 2/2
    • Remove the lid on top of the subwoofer.
    • Flip the device over and let the subwoofer fall into your hand.
    • The subwoofer is a strong magnet. Keep it away from any other electronics and unshielded wires.
  6. Amazon Echo 2nd Generation Front Cover Panel Replacement, Front Cover Panel: 6 단계, 이미지 1/2 Amazon Echo 2nd Generation Front Cover Panel Replacement, Front Cover Panel: 6 단계, 이미지 2/2
    • Remove the four 16.0 mm T8 Torx screws underneath the speaker.
    • Once you unscrew the four 16.0 mm T8 Torx screws, the remaining components of the device have no support. Take caution when flipping the device over to avoid damage to the remaining components.
    • Flip the device over while supporting the front panel side.
    • Remove the front panel cover by lifting it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eric Inman
회원 가입일: 10/08/18
301 평판
안내서 3개 작성하였습니다
Cal Poly, Team S4-G4, White Fall 2018 Cal Poly, Team S4-G4, White Fall 2018 회원
CPSU-WHITE-F18S4G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 26
전체 시간: 1,780
