이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the rubber layer beneath the device.
Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
Remove the four 8.0 mm T8 Torx screws on the lid.
Remove the lid from the device.
Use a spudger to flip up the small flap on the ZIF connector.
Gently pull the ribbon cable out of the ZIF connector.
Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
Use a spudger to lift up one of the small flaps on only one side of the female connector.
Pull on the wire toward the lifted side until the male connector is disconnected.
Remove the AMP Board.
Remove the four 30.0 mm T8 Torx screws in the corners.
Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
Remove the lid on top of the subwoofer.
Flip the device over and let the subwoofer fall into your hand.
Lift the MIC board over and lay it down against a surface.
Disconnect the ribbon cable from the MIC board and pull the board away.
Remove the four 16.0 mm T8 Torx screws underneath the speaker.
Flip the device over while supporting the front panel side.
Remove the front panel cover by lifting it.
Remove the white plastic shielding and the black silicon cover.
Remove the metal cover beneath the black silicon cover.
Carefully lift up the MLB board. Underneath it is another ZIF connector. Use a spudger to flip the small flap on the ZIF connector.
Remove the MLB Board by flipping the device over and letting it fall into your hands.
다른 한 분이 해당 안내서를 완성하였습니다.
