이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Follow this guide to replace the subwoofer in your device if you are experiencing any sort of audio issues.
필요한 것
Remove the rubber layer beneath the device.
Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
Remove the four 8.0 mm T8 Torx screws on the lid.
Remove the lid from the device.
Remove the four 30.0 mm T8 Torx screws in the corners.
Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
다른 한 분이 해당 안내서를 완성하였습니다.
