주요 콘텐츠로 건너뛰기
Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement
필요한 것
  1. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: 1 단계, 이미지 1/3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: 1 단계, 이미지 2/3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: 1 단계, 이미지 3/3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo.
  2. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 2 단계, 이미지 1/3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 2 단계, 이미지 2/3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 2 단계, 이미지 3/3
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 3 단계, 이미지 1/3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 3 단계, 이미지 2/3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 3 단계, 이미지 3/3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 4 단계, 이미지 1/1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 5 단계, 이미지 1/3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 5 단계, 이미지 2/3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 5 단계, 이미지 3/3
    • Remove the silver divider
    • Remove black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 6 단계, 이미지 1/3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 6 단계, 이미지 2/3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 6 단계, 이미지 3/3
    • Remove the ribbon cable from the slot on the LED/speaker board
  7. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 7 단계, 이미지 1/1
    • Remove the LED/speaker board
결론
다른 4명이 해당 안내서를 완성하였습니다.
Cassidy O'Connor
회원 가입일: 10/09/17
450 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G3, Leahy Fall 2017 USF Tampa, Team S1-G3, Leahy Fall 2017 회원
USFT-LEAHY-F17S1G3
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
I can’t seem to find the board anywhere. Where would you buy one?
George hanes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 21
전체 시간: 4,926
