주요 콘텐츠로 건너뛰기
Amazon Echo Dot 2nd Generation Ribbon Cable Replacement
필요한 것
  1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: 1 단계, 이미지 3개 중 1개 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: 1 단계, 이미지 3개 중 2개 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: 1 단계, 이미지 3개 중 3개
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 2 단계, 이미지 3개 중 3개
    • Use a T8 screwdriver bit to unscrew the 1.6mm four screws.
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 3 단계, 이미지 3개 중 1개 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 3 단계, 이미지 3개 중 2개 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 3 단계, 이미지 3개 중 3개
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 5 단계, 이미지 3개 중 1개 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 5 단계, 이미지 3개 중 2개 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the ribbon cable from the slot on the LED/speaker board
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Errica Snelling
회원 가입일: 10/09/17
727 평판
안내서 1개를 작성함
USF Tampa, Team S1-G3, Leahy Fall 2017 USF Tampa, Team S1-G3, Leahy Fall 2017 회원
USFT-LEAHY-F17S1G3
3 회원들
안내서 12개를 작성함
5가이드 댓글
Where do you get the replacement cable from?
jonathan kabitzke - 답글
Yes, where can one get replacement ribbon cables?
Armando Morreale - 답글
Malcolm oakley - 답글
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
Barrie Gash - 답글
no cable available, just waiting for donors
Ray Floyd Cabrera - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 26
전체 시간: 2,941
