주요 콘텐츠로 건너뛰기
Amazon Echo Dot 3rd Gen Disassembly
필요한 것
  1. Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: 1 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: 1 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: 1 단계, 이미지 3개 중 3개
    • When Prying the bottom off, insert the Metal Spudger under the bottom where the ports are
    • Avoid letting the Adhesive touch anything, lay the plate on the branded side
    • If the adhesive is to strong use a hair dryer to soften it
  2. Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: 2 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: 2 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: 2 단계, 이미지 3개 중 3개
    • Use a TORX T6H bit to remove the four screws on the bottom
    • When all the screws are taken out lift up and the covering should slide off
  3. Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: 3 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: 3 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: 3 단계, 이미지 3개 중 3개
    • Remember to un latch the ribbon cable before pulling the circuit board up
  4. Amazon Echo Dot 3rd Gen Disassembly, Removing the top: 4 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: 4 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: 4 단계, 이미지 3개 중 3개
    • To get the further screws on the bottom, use a 4 mm nut driver and put the TORX bit in the nut driver as an extension
    • Pull up on the metal to release the top from the rest
  5. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: 5 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: 5 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: 5 단계, 이미지 3개 중 3개
    • Undo the four screws the remove the white defuser piece (I lost a screw)
  6. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: 6 단계, 이미지 2개 중 1개 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: 6 단계, 이미지 2개 중 2개
    • The two should separate if you hold the edge, if it doesn't push a button on top and it should pop out
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ben Nicholsonb
회원 가입일: 07/09/21
349 평판
안내서 1개를 작성함
3가이드 댓글
Parabéns pelo tutoria de desmontagem do aparelho ALEXA ECHO DOT 3ª geração! Excelente trabalho!!!
Eu recebi um aparelho desse para efetuar a manutenção, pois este estavatotalmente inoperante, por dois motivos:
1° ADAPTADOR FONTE AVARIADO, gerando tensão de saída DC oscilante;
2° MAL-CONTATO NO CABO FLEXÍVEL INTERNO que conecta as duas placas eletrônicas internas.
eduardosanchessales - 답글
How can I convert Amazon Echo Dot power from AC to DC?
Gift Sikufele - 답글
ciao, per caso sai indicarmi la parte specializzata per la rete wi-fi o segnali, ho un eco dot uguale e non viene rilevato in nessun modo per questo volevo vedere se ci fosse qualche problema al ricevitore wifi
Matteo Sala - 답글
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 110
지난 30일: 456
전체 시간: 15,765
