주요 콘텐츠로 건너뛰기
Amazon Echo Dot 3rd Generation Casing Replacement
필요한 것
  1. Amazon Echo Dot 3rd Generation Casing Replacement, Casing: 1 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Generation Casing Replacement, Casing: 1 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Generation Casing Replacement, Casing: 1 단계, 이미지 3개 중 3개
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Casing Replacement: 2 단계, 이미지 2개 중 1개 Amazon Echo Dot 3rd Generation Casing Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Casing Replacement: 3 단계, 이미지 1개 중 1개
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Casing Replacement: 4 단계, 이미지 2개 중 1개 Amazon Echo Dot 3rd Generation Casing Replacement: 4 단계, 이미지 2개 중 2개
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
결론
To reassemble your Echo Dot, follow these instructions in reverse order. Ensure the casing fits properly before tightening the screws back on. Once reassembly is finished, check that the device powers on and functions correctly.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kristen Gismondi
회원 가입일: 11/12/14
99,517 평판
안내서 255개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,729개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 44
전체 시간: 1,154
