주요 콘텐츠로 건너뛰기
Amazon Echo Dot 3rd Generation Motherboard Replacement
필요한 것
  1. Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: 1 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: 1 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: 1 단계, 이미지 3개 중 3개
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Amazon Echo Dot 3rd Generation Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Amazon Echo Dot 3rd Generation Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
  5. Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Remove the four 6.2 mm screws from the motherboard using a T6 Torx screwdriver.
    • Remove the three 9.4 mm screws from the motherboard using a T6 Torx screwdriver.
  6. Amazon Echo Dot 3rd Generation Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Generation Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Generation Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the connecting head linking the motherboard to the device using a pair of tweezers.
    • Remove the old motherboard and replace it with the new one.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jacquelyn Jones
회원 가입일: 09/15/22
308 평판
안내서 1개를 작성함
3가이드 댓글
Where do we get the parts you bi chh
Fcukermother - 답글
Amazon does not sell any parts for the Echo devices. Your best and probably only alternative is to buy a used Echo from eBay and use this guide to repair it.
raymondjram -
Can you get or buy replament mother boards for the ehco 5 ?
Shawn Haywood - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 150
전체 시간: 2,896
