주요 콘텐츠로 건너뛰기
Amazon Echo Dot 3rd Generation Speaker Replacement
필요한 것
  1. Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: 1 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: 1 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: 1 단계, 이미지 3개 중 3개
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Speaker Replacement: 2 단계, 이미지 2개 중 1개 Amazon Echo Dot 3rd Generation Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Speaker Replacement: 4 단계, 이미지 2개 중 1개 Amazon Echo Dot 3rd Generation Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
  5. Amazon Echo Dot 3rd Generation Speaker Replacement, Speaker: 5 단계, 이미지 1개 중 1개
    • Remove the four black 8.4 mm screws surrounding the speaker using a JIS #1 screwdriver.
  6. Amazon Echo Dot 3rd Generation Speaker Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Dot 3rd Generation Speaker Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Dot 3rd Generation Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Use a spudger to pry the speaker out of the device.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elaina Moore
회원 가입일: 09/15/22
187 평판
안내서 1개를 작성함
14가이드 댓글
Now where do I get the new speaker?
Philip Terry - 답글
Now WHERE do I get the new speaker?
vinodhkumar chejarla - 답글
WHERE DO WE GET THE REPLACEMENT speaker!?
Jerry Perry - 답글
I'm not sure if this is gonna work, but I have found a speaker on Amazon which is of the same size, almost the same wattage and same impedance. I'm only not sure about the depth of the speaker.
here is the link: https://amzn.in/d/5CvwhrW
I hope this helped!
Shri Mohan YV -
If you have a new one and the bass is a bit rattly just losten the speaker screws push lightly on the speaker whilst tightening the screws back up. It reduces the pressure and keeps the driver from hitting the case or moving to far out
GrantersG - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 130
지난 30일: 470
전체 시간: 8,806
